5 members (TooMany2count, Nhluvstruck, Wally / Montana, 78buckshot, Brian Moore), 178 guests, and 2 robots.
Topics128,087
Posts1,055,985
Members48,430
#57817 03/17/2006 3:13 AM
Hi, can any one teel me what the numbers are on the 292 that I got, can't find my numbers book right know. ok here are the numbers, on the engine on the dis pad F0526XXF, On the head side of 4883F18 on top of 3864888, 886, H154. I know it is a 292 for sure would like to know what year and what year the head came from and what engine it was off of. Thanks super250six
#57818 03/17/2006 10:15 AM
X
X Offline
Are you sure you read the head casting number correctly? My '68 parts book shows 3864888 as a head for a 153 4-cyl. of approximate '63-'65 vintage.
If it's really 3864883, that would be for a 194 head from '64-'67. There is also a 3864886, for a 230 head from '65-'70. The closest 292 head number would be 3864890 for '63-'66. This info is from here.
The date code H154 would translate to August 15, probably of '64, if this head is any of the above.
Your block ID suffix XXF doesn't show up in my suffix lists through '72 for cars or light trucks (that's all the farther my info goes). If XXF is a legitimate 6-cylinder suffix, and it follows the normal format, a 3-letter code would be from a '70-up engine. Have you found any block casting numbers, or the block date code?
Edit: The XXF suffix may be a crate motor designation, meaning an engine sold "over the counter" as a replacement.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
