7 members (Otto Skorzeny, J Lucas, klhansen, Tronman, electors, 78buckshot, 1 invisible), 106 guests, and 4 robots.
Topics128,042
Posts1,055,497
Members48,424
#577324 09/23/2009 9:34 PM
I ordered a two speed switch, however it had 3 terminals which my single speed does not ( it has two terminals ). I could not get it to work as the plunger for the WS washer pump would not let the knob attach. My burb came to me with no washer pump. Was there switches from 6o to 63 without WS washer kits. If so were there 2 speed swithes without washer kits. I have hooked up a aftermarket washer kit and installed a independent switch for it ( works fine ). Now the problem is can I fine a 2 speed switch ( without the plunger for the washer kit) Couldn't explain it in less words!!!
Any help out there?
EB
not a burb problem, you're more likely to find some help in the 60's forum where more folks have the same gear
Thanks for the tip eb
