| | | Forums66 Topics128,158 Posts1,057,023 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I have a three piece drive shaft for my 60 GMC and want to replace the center bearing and u-joints, doea anyone know about how much it will cost to press one on?
Jake | | | | | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Maybe $25-$35 to press on center bearing + parts. You can do the u-joints yourself, it's not hard. Either a large vise and some big sockets, or a BFH and an anvil or a really stout block of wood or bench. Don't forget the penetrating oil!
*** GMC ***
#5771 03/22/2003 10:13 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Make sure you have the snap-ring grooves cleaned out really well when you put it back together. The center support bearing CAN be a pain to try to do at home unless one has the tools(press and fixtures)
#5772 03/22/2003 10:50 PM | Joined: Feb 2003 Posts: 33 Junior Member | | Junior Member Joined: Feb 2003 Posts: 33 | I use a big c-clamp that I modified by welding a short piece of pipe to the opposite end of the screw,the pipe is just smaller than the yoke on the drive shaft but bigger than the u-joint so you can press the joint out one side remove the bearing cap then press out the other one.it works great and it easy on the u-joint and drive shaft. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I found a local shop I 'll will call monday to see what they will charge for the center bearing, I will asked them while the shft is there to pop in the U-joint, | | |
