| | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 23 New Guy | | New Guy Joined: Sep 2009 Posts: 23 | Hi everyone! I'm new here and the new owner of an old stove bolt. 1950 GMC 3/4 ton long bed. Anyway when I drive her down the road and hit a bump in the road sometimes I get this grinding noise coming from the way it sounds in the rear. to me it sounds like ring gear grinding on the housing. it only does it for a second or 2 then it quits. Where to start looking? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Look at the simplest first. Grease the u-joints and slip joint. Aftermarket center bearings have a grease fitting too. | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | I know it might sound like ring gear- but maybe check shackles- I had a bad one that sounded funny | | |
