4 members (Rich'sToys, Hotrod Lincoln, Hanks custodian, 1 invisible), 114 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
#576523 09/21/2009 9:15 PM
trying to remove the hub assembly with what I assume is the brake drum on my 52 1 ton. Do I need to use a 2in socket to take what I would have called the dust shield first? Then I can get that hub and the brake drum off?
Sounds like you have already figured it out.You may have to back the brake adjuster off a little to get the drum off.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
Ok where would that be?
Start by looking here, you can get an idea what to do. Once at this site you can search for your specific year. You should really invest in a shop manual and or an assembly manual.
Bruce
My Trucks
Stuff I Collect
