| | | Forums66 Topics128,195 Posts1,057,380 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I am the proud owner of five of these original NAPCO 17.5" rims, but I am having difficulty figuring out if these STA Traxion (Fig. B) tires will work on these. The STA are 8 x 17.5", but if you look at the photo below, it looks like I only have 5" between the beads. What do you guys think? I did pull an old military tire off the rim and it had 8 x 17.5 on the sidewall, but the tire was flat so I have no idea if it actually worked. 17.5" NAPCO rims The previous page shows the overall diameter of the rim. | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I'm trying to figure out what you see as a problem. The tire you want to mount is the same size as the one you took off, right? A 17.5 wheel and a 17.5 tire, sounds like a match to me. As far as the width of the tire is concerned it will work,and the only thing I've ever thought about is the stance or how it looks once mounted on a wheel. Wider tires can be mounted on the same width wheel as a narrower tire, the only thing is how the stance looks. Meaning a wider tire will have the sidewalls pulled in more than a skinnier tire. The only other thing that comes into play is how flat the tread sits on the pavement with X number of pounds in the tire, which I don't think applies in your tire dilemma but I just thought I'd mention it. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I see what you are saying. But see where is says "Rim width" on that STA site? It says 6". Mine are over 6" wide. Does that mean these tires will fit a rim with a 6" minimum width? Is that the overall width, lip to lip or bead to bead?
I am about 80% sure they will work, but I would like to be 100% before dropping $800. When I spoke with the dealer they started throwing out things like; "it has to have a minimum of 5.5" between the beads". I will send the dealer the photo and make him guarantee they'll fit!
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The tire specifications says 6" rim width. I'd say your an 1" shy.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Too narrow of a rim will cause handling problems due to lack of proper sidewall support. Rim width is measured from flange to flange on the inside of the rim. For a 5" rim, you'll want a 7" tire, max.
Bill Burmeister | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Just spoke with the manufacturer and he broke out his dusty old book on rim sizes. I guess this is the one that all tire manufactures use as their bible. Apparently, my rim measuring 5.25" from bead to bead is the exact correct rim for those STA Traxion tires. He admitted that he will be running down to the engineers to fix their website and catalog which lists the correct rim width as 6".
I finally feel better. Now to order those babies!
| | | | | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | My '68 C/10 stepside was originally ordered with 17.5 [X 5.25 - 6 lug]rims and 7.00 x 17.5 bias tires. In the mid '70s, when I couldn't get 7.00s any more, I went up to 8.00 x 17.5. No problems, just more bounce and "slower" speedo readings but a 292 L6 was well able to maximize torque to make this work. In the '80s, I went to radials, 8R17.5. After about 300,000 miles of agressive driving, including a lot of 2-wheel off-roading, the factory rims were shot. I couldn't find any replacements in that size. I tried other rims more suited for V8s [8 x 15] but eventually went with 7 x 16 white spokes and 235/85/16RT radial rover Dunlops. On the 17.5 rims, my favorite tires were Yokohama model 703. Kind of knobby but OK on the freeway.
Every 25 years I like to rebuild that 292 just for GP
