Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (78buckshot, Otto Skorzeny, Hotrod Lincoln, Lightholder's Dad, 1 invisible), 219 guests, and 4 robots.
Topics128,285
Posts1,058,533
Members48,490
Glad I found you guys. I just picked up a 1957 3100 shortbed. I already had the Camaro subframe, rear end and column (1980 Z28) for this truck. I have no problem doing the subframe work I would just like to see more photos of how you all have done it before I cut. I'd love to see some of the local St. Louis ones in person.
Isn't there a set of frame brackets out there that allow you to hang the Camaro rear and springs with out much modification?
Also, I know the '57 fenders are different than the '55 and '56 but is the actual grille opening the same so you can run a '55 or '56 grille?
Any help would be appreciated. Thanks! New Guy
Welcome aboard.
You would get more responses in the Hi-Po section of the forum.
You may also want to run a Search
Here is a link I started that my be helpful .
I personally do not like clipped vehicles as there is always a chance of a stress crack starting where the two sections are joined.
Scott
If you dont find what you need I have a 49 in the shop with a77 Camaro front clip.Just let me know .
