| | | Forums66 Topics128,214 Posts1,057,488 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57513 03/08/2006 2:45 AM | Joined: Nov 2005 Posts: 39 Apprentice | | Apprentice Joined: Nov 2005 Posts: 39 | Ok, I'll try here......what is the widest rim and tire (P275 60 R15??) I can fit on a 51 1/2t using a 1957 passenger car housing???? Anyone know????
Thanks, Tom
1951 Chev.P.U. Streetrod-project 1951 Chev cpe 261 5-speed-50% 1953 Chev cpe 350/700-95% 1962 Chev Bubbletop 409 -75%
#57514 03/08/2006 2:56 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | A 10 inch wheel will fit but I have no idea of what back spacing you would need with a 57 car rearend, we always use 9 inch ford that we cut to length and have Moser respline the axles-only $85.
Evan
#57515 03/08/2006 5:48 PM | Joined: Nov 2005 Posts: 39 Apprentice | | Apprentice Joined: Nov 2005 Posts: 39 | coilover: Thanks for the info. The 57 measures 60". What do you cut yours to? A 10" rim?????? with stock outboard shocks??????? Or do you have to mount the shocks inside the frame?
BTW, I'd like to use the Ford 9" but I've got a rebuilt 4:11 posi and it's going behind a 261 with an S-10 5 speed. I think the 57 should hold up well. Is ther a typical range of price for the Ford 9"?
Tom
