| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 45 | The color I need to change to is the 'off white' or 'light tan'. I don't know the proper name for the color so please set me straight there. My main question is, does the paint from LMC called 'off white' match the factory color or at least very close? I'm not shooting for perfection with this project. Are there other products available? THX, Doug
I guess I should add: it's a 63 | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | If you want to paint match, then go ahead and get your paint matched!You will not find a "63 Chevy truck interior paint" anywhere. And if you did, it would probably be wrong anyway. Find a piece or section that can be "shot" by your local auto parts place, and they'll make you up a spray can of paint in the same color as your sample. Glovebox door, ashtray, radio delete plate, even the inside of one of those might have the right color on it. The spray bombs are under 20 bucks each( I think I paid $11.00 ). Call around to find out who does that in your area. | | | | | Joined: Mar 2009 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 45 | We have several places that can make up the spray cans but getting something to match is the prob as the truck I have was done is some sort of custom copper color. | | |
