If you want to paint match, then go ahead and get your paint matched!You will not find a "63 Chevy truck interior paint" anywhere. And if you did, it would probably be wrong anyway. Find a piece or section that can be "shot" by your local auto parts place, and they'll make you up a spray can of paint in the same color as your sample. Glovebox door, ashtray, radio delete plate, even the inside of one of those might have the right color on it. The spray bombs are under 20 bucks each( I think I paid $11.00 ). Call around to find out who does that in your area.
