4 members (Hotrod Lincoln, Canadian Dump, Dennys28, Phak1), 130 guests, and 4 robots.
Topics128,165
Posts1,056,987
Members48,458
#573846 09/14/2009 1:05 AM
Hello Everyone
I am finally starting to work on my truck after almost 4 yrs, hurray.
Now here is my first of many questions I will be having. I have a ¾ ton 1953 pickup and I would like to change it to a ½ ton. Question 1. Is the frame the same on both trucks?
#2 what do I have to do to the suspension on the frame?
#3 I want to keep the straight axel at this time what do I have to do the make it a 5 bolt rim.
Thank you for any help I can get.
Roger
The frames are not the same. The 3/4 has a longer wheelbase and
the rails are parallel from the cab on back, where the 1/2 ton frame is tapered from front to back.
The front springs are the same for both models.
You can swap a 1/2 ton front axle in place of your stock axle and get a 5 lug disc brake kit or use 5 lug car hubs if you don't want discs. And of course you can change out the rear for a 5 lug rear axle. These mods would really make your truck more like a car than a 1/2 ton.
Steve
'49 3800
'52 3600
'57 3100
Thanks for the reply. So there is not really anything I can do to this frame to make it a ½ ton. Is there anything I can do to get it to ride any smoother? I want to replace the rear axel to get a better high end on the road. I am going to use the original 235 that is in the truck and change the tranny to a 2 speed power glide.
You can try some poly spring liners and some guys take a few leaves out of the 3/4 ton rear spring pack. (do so at your own risk)
Keep in mind it's an old truck made to work and haul loads, not ride smooth like a car.
The original engine for your truck would be a 216, not a 235.
Steve
'49 3800
'52 3600
'57 3100
Originally Posted by Ghostrider
...The front springs are the same for both models...
They may be the close to the same and interchange just fine, but the 3/4 ton springs hold more weight (barley), should be thicker leaves. At least that's how I see it in the truck data book, but still somewhat confusing.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I don't have a truck data book.
When I had new main leaves made for my 3/4 ton at an old school local spring shop, the guy had mentioned to me that the spring packs were the same for 1/2 and 3/4 after looking up the specs.
The Chevrolet Master Parts Catalog also lists the same part number for '47 to '55 1/2 and 3/4 ton (except D-D) for front springs. I've also compared my 3600 springs with ones on a 1/2 ton parts frame that I have. That is how I got my information.
Steve
'49 3800
'52 3600
'57 3100
Thank you for the info and yes you were right, it is a 216. Now I have a 235 from a 1956 truck I could put in it. but it has an original motor in the truck an it runs. I am not sure which way to go with it. I would love to be able to drive it around longer distances. Or just give up and get a 1/2 ton frame and do alot of changing. How bad does a 3/4 ton truck ride and drive?
Drives like a truck, it is a truck, that's a good thing in my book.
My 1 ton took me around the country (8,000 miles in a month) as well as everyday driving for a couple years, it was great fun.
To change anything would be slightly faster gears, but not real fast; still need it to haul stuff (it is a truck). With the 32" tires and a 235 4.11 gears would be great, 3.73 would be to fast. As it was I had 5.14 gears when I drove it everyday, and 4.56 gears for the big trip.
But it depends on how you want to use it.
If you can drive 50-60 mph them mostly stock possibly with faster gears would be great.
If you want to travel with traffic on the highway you probably want more than a gear change. Think about brakes, steering, and more power.
Does it run and drive as is now?
I'd run it for a good while, before deciding to change lots of stuff.
Grigg
---All pictures---
