0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 20 New Guy | | New Guy Joined: Oct 2008 Posts: 20 | I have a 57 6100 Chevy that I got couple months ago. I noticed that the truck had no shocks and had no brackets for shocks.I don't know to much about these big truck. But I thought it would have shocks like the little ones.Could someone have cut the brackets or did the truck come factory with no shocks? | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | I don't think the big trucks had shocks. My 45 doesnt have them either. My service manual shows the suspension without any shocks. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | trucks above 3600 don't even have a cross member that would mount the shocks, although I believe they were optionally available on 1 tons - with the size of that rear spring pack it's unlikely any damping would be needed or useful  Bill | | | | | Joined: Oct 2008 Posts: 20 New Guy | | New Guy Joined: Oct 2008 Posts: 20 | I was just wondering because I have a 55 shop manual that shows a 2 ton frame with shocks. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if you check the intro of section 2 in the manual, you'll see where it states front shocks are an option for 1.5 and 2T
Bill | | | | | Joined: Oct 2008 Posts: 20 New Guy | | New Guy Joined: Oct 2008 Posts: 20 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ..with the size of that rear spring pack it's unlikely any damping would be needed or useful  Bill At higher speeds they may be helpful. Even semi trucks and locomotives have shocks these days. Talk about some stuff springs! check out a rail car... I have brackets and plans to add shocks to my 2 ton. Grigg | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the back, as I said above, doesn't even get the cross member that mounts the shocks - I'm sure under some circumstances there might be a just noticeable difference with front shocks, but at the speeds these trucks were capable of loaded, rear shocks would be a waste of money .... high GVW buses had/have shocks too, but modern semi suspensions are quite a bit different from '57, as are roads - these trucks were designed and priced to be worked to death rapidly, not to be driven empty or provide passengers the smoothest possible ride
Bill | | | | | Joined: Oct 2008 Posts: 20 New Guy | | New Guy Joined: Oct 2008 Posts: 20 | Thank you for all the info guys!! | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Shocks? We don need no steenking shocks! :P
Altho, between the bounce on the front and my springy seat, I could go for some up front for sure. Been a couple times when I felt like a rubber ball in a shoe box. The back end tho, when it's empty that spring stack barely flexes. Might look at adding on some front shocks when I replace the springs, if I ever have money again that is. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Both my 10500 Series 1957 Fire Engine and 8400 Series 1956 Tow Truck have front shocks. They are both 2-1/2 ton rated. Mike B  | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | My 1952 GMC 470 series COE, also has Factory front shocks. It's rated at 3 1/2 tons. | | |
