1 members (1 invisible),
368
Mod | | | Forums66 Topics128,162 Posts1,057,043 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 90 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 90 | My motor makes noise at idle, sounds like a dry bearing crossed with a straight cut gear. It doesn't sound like the alternator.
It does not amplify with higher revs and I don't notice it driving down the road.
Could it be normal timing gear whine?
Thank you,
Ray | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | If it's got an aluminum cam gear, they're a little more noisy than the fiber gear. The metal gear lasts a little longer, however. If you're not sure about the source of the noise, drop the fan belt off for a short time, and see if the belt-driven accessories are contributing to the whine. Also have someone push the clutch pedal down and see if the noise changes. The throwout bearing, and the transmission cluster gear bearings can also make some strange noises. Jerry
| | | | | Joined: Oct 2005 Posts: 90 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 90 | Thanks Jerry, Depressing the clutch doesn't change things, but my sm420 definitely makes some noise of it's own, noting alarming.
I'm going to remove the belt to rule out the water pump and alternator.
It disappears under load which makes me think it might be the gears. It is an aluminum timing gear
It was less noticeable with a different carb, does that make any sense? | | |
