10 members (Drew54, Otto Skorzeny, klhansen, 46 Texaco, Stovebolt48, tclederman, J Lucas, Maybellene, 2-Ton, 1 invisible),
106
Mod | | | Forums66 Topics128,281 Posts1,058,488 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 11 New Guy | | New Guy Joined: Jun 2009 Posts: 11 | i have a 53 truck im restoring, im only 27yr old and im trying to restore my truck. the motor thats in it as i was told was og and when futher inspected the og color was blue and never painted. so to really find out i cant find the id numbers on the block to research and find out what i have. so if anyone knows where i can locate these numbers and maybe a website i can do the research on would be very helpful thanks branden | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | The numbers are on a pad directly behind the distributor cap. You may have to scrape off some grease to get to it. Someone here(not me) should be able to identify the year and other info on the block. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Someone here(not me) should be able to identify the year and other info on the block.  With the engine being blue, and apearently not repainted, it points to it being a Passenger engine. Truck engines were for the most part a bluish-gray, although manual transmission Passenger engines were also that color. Like Jordan noted, there is a number stamped on the machined pad just behind the distributor. If there isn't a number there (factory replacement engens were't stamped), there also are several casting numbers that can help ID it. One is the block casting date, which is located on the right side of the block, right behind the starter. There's also a part number cast on the same side of the block, but further toward the front. The head castting number will be on the LF portion of the head, on the top ledge fairly close to the lip of the rocker arm cover. Any of those will get the approximate year/application, but the stamped ID number by the distributor will peg the exact original application.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 11 New Guy | | New Guy Joined: Jun 2009 Posts: 11 | thanks for all the help, will check when i get to the shop in the morning and post up what i have found and thanks for all the quick replies and 1 more thing the parts truck i pulled out the woods in the back of the bed it had a 235 in it and it was a green color so would that make it a thrift master | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Green? That one could be one of 2 things. 1, a Jasper reman (they used to be painted green) or possibly 2, a 261. If it's the latter, it would not be an original engine, as they were used in 2 ton and larger trucks/ However, if it IS a 261, that's a MAJOR JACKPOT!! great upgrade engine. Full pressure oiling, more power, if it's a '58 ir later, full flow oil filtration. In the tech tips section, there is an ID guide on how to tell if it is a 261, namely, how to identify the Captains Bars that are cast on the block. If you can, get the numbers from both engines, and perhaps some pics.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 11 New Guy | | New Guy Joined: Jun 2009 Posts: 11 | ok i will take pics, numbers in the morning | | | | | Joined: Jun 2009 Posts: 11 New Guy | | New Guy Joined: Jun 2009 Posts: 11 | ok i finally got around to getting the block number and this is what i got F12IbJ any help or websites that i can find out what i got would b a great help | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Don't see that exact code, but could it be that perhaps the "LB" (weird, that's my handle on Gearz) is actually "18"? If so, that decoded to a 235, Flint plant, built on 12/18, and could be a '58-'62 1/2 ton w/manual trans engine. There should be a cast date code just behind the starter which will give us a closer manufafture date.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 11 New Guy | | New Guy Joined: Jun 2009 Posts: 11 | ok how bout this num located under the distrb 3769716 | | | | | Joined: Apr 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 67 | 1958-62 235 . Thats what I found in Patrick's book. | | | | | Joined: Jun 2009 Posts: 11 New Guy | | New Guy Joined: Jun 2009 Posts: 11 | kool thanks and do u know the specs or any knowledge on these motors | | | | | Joined: Jun 2009 Posts: 11 New Guy | | New Guy Joined: Jun 2009 Posts: 11 | behind the starter CON4 L150 left side of the distrubter F12IbJ (engraved) under the distrubter to the rite a lil 3769716 | | | | | Joined: Jun 2009 Posts: 11 New Guy | | New Guy Joined: Jun 2009 Posts: 11 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 3769716 = 58-62 235 L150 = Dec 15th 1960 F12IbJ = ?
Tim
| | | | | Joined: Jun 2009 Posts: 17 Apprentice | | Apprentice Joined: Jun 2009 Posts: 17 | can someone also help me with mine please here they are. thanks early. i was told it was a 235 out of a 62 biscayne. just like to make sure or find out what exactly i am dealing with.
3769716
con4 c71
number on the head is b56 848 85 | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | The casting number for the head should begin with 383xxxx.
You could get lucky and it's 3836850.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 3769716 = 1958-62 235 truck block con4 c71 = C71 date casting code = March 7 1961 ? b56 848 = is a code that no one has explained 85 Here are locations of all the codes. | | | | | Joined: Jun 2009 Posts: 17 Apprentice | | Apprentice Joined: Jun 2009 Posts: 17 | thanks for the help. i will check the head later | | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | The casting number for the head should begin with 383xxxx.
You could get lucky and it's 3836850. Just curious as to why the 850 head would be the lucky head to have. I thought the 848 head was the good one do to its compression?? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Well, if it is not a 235 block, then an "850" might indicate a 261 head. However, an "850" head on a 235 block is not really something special (lower compression than a 235 head).
