| | | Forums66 Topics128,151 Posts1,056,989 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | I have a 58 chevy 3200 235 3 on the tree.
Bone stock - no fuse box, no radio aftermarket heater etc.
The original wire harness is still intact and entirely unmolested - I really cant believe how clean the wires are.
But I have this one problem. The factory turn signals. I just put in a new flasher. 3 prong - powered not thermal (because I run LED's).
When I lift on the lever to indicate I am turning right. The left tail light comes on and I get no flashing.
When I push down on the lever to indicate I'm turning left - the right tail light comes on and again no flashing.
This happens with or without the flasher plugged in.
any thoughts?
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Loose ground somewhere? Was everything fine before you changed to LEDs?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Everything worked the same before I switched to LED's and there was no flasher in the truck when I brought it home.
I'll go through the grounds this weekend.
Anyone know where the factory grounds are located? I assume there should be one on each tail light. Where else? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There are no factory ground wires. You need to make shure the studs & nuts are clean that hold the lights on & the brackets that bolt to the bed. Also you should put a ground wire from the frame to the bed. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I am going to guess that the leds don't draw enough current to trigger the flasher. It seems like I read somewhere that you should use a 100 ohm resistor per side. Don't quote me on that I am about 85% sure but best wait for confirmation. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | He is using an electronic flasher. It doesn't work off resistance.
I agree it's the grounds. The signal is finding a path to ground through the taillight filaments. Follow Wrenchbender's advice. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Is it possible that they are wired backwards at the switch ? Sounds like a ground issue also. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | Grounding issue sounds like ? I had a similar problem on my '58. You have to remove paint from brackets and body to get a good ground ? I played with it just using a wire and looking for grounding areas until it all worked ,then made the install. Good luck. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Say Midget Farmer, does your handle have to do with your anatomy or the size of your farm? George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Say Midget Farmer, does your handle have to do with your anatomy or the size of your farm? George Size of the farm - I have 2.5 acres just outside of town. In the midget farms subdivision. I was so tickled by the sub division name (50 years old) that I christened myself the Midget Farmer. I even bought a 1949 Farmall Cub to mow my grass! As far as the lights go - Tomorrow I'll get out there & play around with ground wires until I can get them working. The bolts are pretty rough - Hope this works!
| | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | It almost seems that you are putting power to the brake light switch lead on the signal switch if the opposet tail light comes on. Could you possibly have plugged the wrong wires into the flasher?
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The reason the opposite light glows is because the electricity is going from the source through the brakelight filament, finding no ground there it travels across the tail light filament, through the tail light wire to the other side where it travels through the other tail light filament. | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | I installed a clean ground wire on both tail lights. I used the dremmel to clean off a spot on the frame & used a stainless steel bolt with di-electric grease.
This did not correct the issue.
In addition - while I was backing my truck into the garage where it was a little darker & easier to see the lights I noticed I had no brake lights.
I started playing around & found out that with the turn signal switch centered I have no brake lights. With it kind of activated (enough to turn on one light but not all the way on) both brake lights work normally. With the switch all the way activated I only get brake lights on the side that is lit (opposite of switch).
I'm about to replace the entire wire harness just because I don't like mysteries. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like a problem in the turn switch. The brake lights go through the turn switch so the side that is on is flashed. Dont give up on this electrical stuff. With a test light & a little logic you can solve any problem. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Sounds like maybe just some crossed wires but you said the wiring was unmolested. Bad switch maybe? Keep us posted on your progress. Jeff
1957 GMC 150
| | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | I'm thinking the key is how the 3 prong flasher is wired in. One lead on the old 2 prong should be acc power and the other to the load (signal switch). Where did you pick up the 3'rd wire and how are they plugged into the flasher?
Joe McNeel
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The extra wire on a 3 term. flasher is for a dash indicater light, if you use one light for both sides. I think it is marked L. You don't have to use it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | I have both a 2 prong and a 3 prong flasher I could use. I first thought it was a two prong as I only saw 2 wires with plugs on them. But as I crawled under to plug it in I found the third. They are all right next to each other. I just assumed they are all for the flashers.
I used the test light to find the hot wire & have it correct. The other two are anyone's guess.
I'm not going to mess with it for a while - I have brake lights when I need them at the moment & don't plan to drive for a while.
I just received my new intake gasket so that will be be my project for the weekend.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The 3 prong is marked "+" for voltage in, "L" for load, and "P" for pilot light. | | |
