| | | Forums66 Topics128,090 Posts1,056,018 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Not the front or back glass, but the door glass.
My 58 apache 3200 doors are pretty much solid except for a couple of small access panels.
I don't for the life of me know how to take out or for that matter put back in the glass. My drivers side window is all busted & I know I'll pay through the nose if I take it into a glass place. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | you have to take the vent window out also,there are four screws around the outside edge of the vent window and two about midway down the door. Then two screws holding the door window to the track, lower the window a little bit and look through the big hole in the middle of the door, they are in the track,however they are the screws that you need the speciaal driver for( available at napa and most of the suppliers). Then roll the window down and pull the vent window up and out, when you are almost out you will have to turn the vent window to fully remove it from the door, then you can remove the other window. good luck
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's described pretty well in the shop manual Midget Bill | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Nice! I knew I could count on you guys!
| | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | I managed to take the good glass out of my old rusty door & install it into the "new" rust free door today.
Thanks for the info - it really helped. Tomorrow I'm going to install the "new" door on the truck. | | |
