7 members (TexasJim50, rick46ia, cmayna, Southerntruck, SNOYL, ShopRag, Mike Roache),
45
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,006 Posts1,055,271 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 66 | Sorry, Let me rephrase this. I have the ID number, can someone remind me where to find out the year, etc. I know it is the not original motor, the valve cover is from a later model. Thank you, Scott | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The casting date above the starter.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'm assuming you want to sit in your chair and find on the internet the specific application for your engine based on it's serial number. I know of no place to do that. However, by the date code, you can find out when the block was cast. This was pointed out in your previous post. Talk about getting old. | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | con 4 1 29 9 - jan 29 '59? is that 1 an I for sept?
my '58-'62 block has con 4 A 11 1, and it's my understanding that it means jan 11th '61. and on the distributor 'ledge' is, F0111A, which repeats the day/mo/yr but also says that it came from the flint, mi plant | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | rednate, yours is a '61 passenger car base 235. A truck engine would have had a J, JB, or JC code.
Bill Burmeister | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | F0111A, passenger car base 235 - ok. but that wouldn't affect the conveyor 4 A 11 1 would it? the A 11 1 is still the designation for january 11th '61 correct? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
