| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 128 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 128 | i have a broken main leaf on the pass. front of my 55' first series 2 ton. ive contacted what was Chevy Duty and Jim Carters with no help in finding a replacement, i also spoke with KC Spring of Kansas City,MO and still drew a blank. Any one have any suggestions in replacing the main leafs or both front springs? im in the kcmo area. thanks in advance. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | http://www.eatonsprings.com/They made my 48 2 ton springs, all new. Also do a search on this site, we have discussed having stock or custom springs made several times. I was and am very happy with Eaton Detroit Spring, but you have other choices that may be as good or better. Grigg | | | | | Joined: Nov 2007 Posts: 128 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 128 | the guy at KC spring told me $300 just to fire their ovens not including the rest of the cost just to make one leaf. | | | | | Joined: Nov 2007 Posts: 128 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 128 | just checked out the eaton site, great, ill be giving them a call tomorrow. thanks Grigg! | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Where you located? I might be able to help you out, I've got a couple parts trucks, if you don't mind used. You coming down for the truck show? Mongo | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Check with these guys.
Bruce | | |
