5 members (1955 1 Series, 3800GUY, Shade Baby, TooMany2count, Bluesky54), 131 guests, and 2 robots.
Topics128,110
Posts1,056,274
Members48,439
Hopefully I can word this correctly.
Excluding the rear axle clearance hump in the frame rail,Is the TOP of the short 18" ish section of frame rail thats behind the rear axle hump supposed to be even, lower, or higher than the TOP of the front section of the frame rail?
If higher or lower can someone please give me a measurement?
Thanks in advance for any help.
Roger
The frame height dimensions would be the same if you measure the top frame height at the front spring perch nearest the front of the cab and the height of the top of the frame at the furtherest rear spring perch. The leading front of the frame slopes,so you can't measure at the front horn. Keep in mind that an assembled truck does not sit levelso it would be important to level the frame before measuring.
Drew
The rear section of the frame behind the axle clearance hump had been cut off. I have this section and want to get it welded back on where it belongs. In some pictures that I have looked at it appeared that this rear most section of frame was a little higher than the rest of the main frame but it didn't make sense to me that it would be higher.
There isn't a bed on the truck right now so in theory could I just take a nice long rugged piece of angle iron, clamp it to the main section of frame and and then clamp the back section up to the bottom of the angle iron and weld it?
Thanks for the information
Yes, you could do it that way. Just make sure everything aligns per dimensions provided in Scott Danforth's link. You may want to consider plating or boxing the weld for added strength.
Drew
Apprentice
Apprentice
The top of the frame behind the cab is level except for the hump.
The box mounts with equal thickenss blocks between the box and frame at all mounting bolts.
Life is simpler if you plow around the stump.
I got it welded back on and fish plated it too. It came out good.
Thanks for the help!!!
Glad to hear that. If you can post pics,pleasedo.
Drew
