3 members (moparguy, texas46, Gray_Ghost), 191 guests, and 3 robots.
Topics128,108
Posts1,056,236
Members48,437
#563914 08/11/2009 1:44 AM
After several months of parts gathering, saving $$$`s for dual exhaust and rebuilding carbs, I had the truck running this afternoon. My newest problem is linkage. I am using Fenton split manifolds, Fenton dual intake and a pair of Carter W-1 574s carbs. I have 3 different bell cranks and the Fenton stainless linkage kit. Has anybody gone with the same set up and can you post or send me some pictures? The throttle arms on the carbs when attached to the rod to connect the carbs is too short causing interference with the float bowl.
1955 Chevy 3100
Spent the better part of 2 days but utilizing the stock hardware and a bit of bending, grinding, swearing...managed to get it close. With a few more hours of tweaking, should be able to get it right.
I would post some pictures but still can`t figure out how.
1955 Chevy 3100
Managed to get it all to work.
1955 Chevy 3100
wowie-wow-wow! looks and sounds sweet
i'm considering the same set-up; why did you choose duals?
Dual carbs or dual exhaust? Wanted something different then the old 350/350 combo. Next mod will be the T-5 transmission.
1955 Chevy 3100
hb32,
Nice looking set-up.
What is the black thing at the left front of each carb?
Tim
hb32,
Tim
It is a cover that protects the accelerator pump. linkage
1955 Chevy 3100
dual boths - good sound, better performance, better mpg? it really did sound smooth and sweet, as in, i'm behind the wheel of an f250 tdi and SO tired of the noise
Does sound very good and the carbs add to the look as most people have no idea what they are. A little slugish off the line and I credit that to the 70 year old technology. Gas mileage is not much better and hope the 5 speed improves that. Not really driving it for economy though wink
1955 Chevy 3100
Red dot, center of chest ...
The 5-speed will help some, no matter what rear end you have. I have a similar setup on my '48, except my carbs are the dreaded Rochestor Model B's. Here's a pic. More than one person has asked me if I have a V-8 when they hear the engine. It's funny seeing the look of shock when I open the hood and they realize it's a straight six.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Looks really good Paul. I am on the hunt for air cleaners and like the look of the 38-47 truck copper filter type but am having a problem getting ones to fit the W-1`s.
1955 Chevy 3100
that's a beauty. but yikes! what's the 8 hose plumbing on the right side?
8 hose plumbing??
1955 Chevy 3100
Looks like the air conditioning and heater hoses to me.
1951 3100 Chevrolet
Yup, they sure do sound good. here's mine. wave
Bill Burmeister
Big Bolt Forum Co-moderator
Why is it the dreaded Rochestor Model Bs? just curious.
1948 Chevy 2-Ton
They have a nasty habit of leaking, float bowls cracking, and the bases warping. I've seen them do all 3 at the same time.
Bill Burmeister
