2 members (Hotrod Lincoln, Bill Hanlon), 66 guests, and 1 robot.
Topics128,049
Posts1,055,677
#56959 02/24/2006 4:58 AM
Have a 1950 250 GMC, Looks like the rims are from a newer 8 lug truck since the dome hub cap will not fit over the hubs. These hubcaps were originals from a 1 ton truck so I thought they would fit? Also no clips on existing rims. Do the dome hubcaps fit the 250 series or will I have to get some original rims to make these work?
crowsgmc
#56960 02/24/2006 7:55 AM
Do you have the big hubcaps? Is there a raised ridge around the wheel where the hubcap could sit?
1954 GMC De Luxe COE
#56961 02/24/2006 4:01 PM
this might help you make them work ???
see:
http://www.speedprint.com/Deves50/hubcapclips.php
clips are $1.25 ea from chevy duty?????
Jim & Caroline
#56962 02/26/2006 2:24 AM
If I am not mistaken, those clips from CD would be for the 1/2 Ton?
What do you call the chrome ring behind the hubcap in Deve's hubcap photo? I know that the outer one is a beauty ring. The inner one really makes the whole job worthwhile because it hides the out of place larger diameter ridge on the rim.
1951 1 Ton Completed
#56963 02/26/2006 4:10 AM
the clips work for the 3/4T too - if there's another ring right around the cap [can't really tell], it's something home-rigged, prolly to hide the fact that he's using wrong later rims that have the built-in bumps for the later style hubcaps
#56964 02/28/2006 12:41 AM
I have a variation on Daves project.
I have seen the clips used on the flat surface between where the lug holes are located. A little different than Dave's side of the rim placement. you may wish to use 3,4 or 6 clips per rim. Then a short piece of tubing, be it copper, stainless or steel about 1/4 - 3/8'' diameter was placed so the fixing clip was placed on top of the short tube. You could then use a 10 or 12x24 machine screw to hold the clip in situ. There is room on the back side of the non stock rim for a nut. The tube may even be as long as 3/4 - 7/8'' (you will have to play w/ that distance to figure out your hubcap to clip and rim retainer tension. The distance or placement of the drilled hole is also determined by you playing around w/ placements. I suggest you buy a couple extra spring clips, they are adjustable to a point and brake suddenly.
this should work on 1/2, 3/4 and possibly 1 ton rigs.
I believe the ''second ring' is in the photo shot and not available, or as red58 says home made. It may also be the rim was painted silver and the cap then was a topper.
have fun
Jim & Caroline
#56965 02/28/2006 2:49 AM
I have wheels from a 91 on the rear of my truck. The front still has stock wheels due to the tie rod clearance problem. My changes were similar to what is on Deve's page, but I added a spacer under the clip and threaded the holes in the rims, rather than using nuts. And I guess I'm guilty of using thw wrong rims with the bumps. I wasn't aware that GM made one-piece rims for the 3/4 ton without the bumps for the dog-dish hubcaps.
[img]http://www.myoldtruck.com/gallery/files/2/3/8/Clip1.jpg[/img]
[img]http://www.myoldtruck.com/gallery/files/2/3/8/Hubcap.jpg[/img]
Fred
52 3600
69 C-10
#56966 03/07/2006 5:00 AM
Thanks for the great response. From the photo it is the later rim and the clips that should fit as they were shown in Deve's or Fred's photos.
Glad as these are the larger dome hubs and would like to use them until I can locate some original rims??
Thanks Again...
Crowsgmc
