2 members (Hotrod Lincoln, Millenimech), 76 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#56926 02/23/2006 6:48 PM
i'm rebuilding a 58 261 i picked up. it's bored .125 over, jahns high compression pistons, cam says 272 on the end. i re-ringed it, new bearings. i'm wondering if i should put high flow oil pump in it or stick with stock. its got hydraulic lifters in it. thanks for any info.
#56927 02/23/2006 8:45 PM
If it helps, my friends healthy 261 has a stock oil pump. We did shim the relief spring with washers so it doesn't bypass until 60 psi.
To shim, he found a washer that was a snug fit in the spring hole. Addes a few washers and put on a guage with an 1/8" fitting on it to constrict the flow. Sat that in a pan of the oil he was going to run and spun the pump with a drill, usuing the priming tool. Then adjusted the number of washers.
Fred
52 3600
69 C-10
#56928 02/24/2006 12:07 PM
knuckle head
knuckle head
There are no hi volume oil pumps available,only the stock type pump.
A 228-302 GMC oil pump flows about 20 percent more oil,the relief valve is set at 55-60 psi .It's fairly easy to install the GMC pump in a Chevy by reworking the external oil feed line and pick up tube.
