| | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56926 02/23/2006 6:48 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | i'm rebuilding a 58 261 i picked up. it's bored .125 over, jahns high compression pistons, cam says 272 on the end. i re-ringed it, new bearings. i'm wondering if i should put high flow oil pump in it or stick with stock. its got hydraulic lifters in it. thanks for any info. | | |
#56927 02/23/2006 8:45 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If it helps, my friends healthy 261 has a stock oil pump. We did shim the relief spring with washers so it doesn't bypass until 60 psi.
To shim, he found a washer that was a snug fit in the spring hole. Addes a few washers and put on a guage with an 1/8" fitting on it to constrict the flow. Sat that in a pan of the oil he was going to run and spun the pump with a drill, usuing the priming tool. Then adjusted the number of washers.
Fred 52 3600 69 C-10
#56928 02/24/2006 12:07 PM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | There are no hi volume oil pumps available,only the stock type pump. A 228-302 GMC oil pump flows about 20 percent more oil,the relief valve is set at 55-60 psi .It's fairly easy to install the GMC pump in a Chevy by reworking the external oil feed line and pick up tube. | | |
