0 members (),
52
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 17 New Guy | | New Guy Joined: Jan 2009 Posts: 17 | Hello, does anyone know where you can buy a step plate with a GMC logo.My running boards are freshly painted and don't want to scuff them.I have seen a set that has been stamped but don't really like them.Can you get a machined set? | | | | | Joined: Nov 2008 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 101 | | | | | | Joined: Nov 2008 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 101 | Jimcartertruckparts.com
P. A. They're not stamped; that would indicate a forging most likely. They're cast metal. Probably aluminum. As far as I know, no one would take the time to machine them....unless of course you bring money. Then you can get whatever you want made I suppose. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Assuming you are referring to 47-55 GMC: The 47-55 GMC steps plates at JC's that Dan refers to are GM licensed Restoration Parts. These are probably the best reproduction you will find. If you want to be certain that they are not pressed-metal, call JC and ask (they are most likely cast - not machined). | | |
