Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (UnclePaddy, Peggy M, Oswald), 105 guests, and 3 robots.
Topics128,281
Posts1,058,460
Members48,490
#567855 08/24/2009 3:06 AM
Apprentice
Apprentice
I just pulled out the drivers seat to install my new matching seats when I discovered that the seat I just pulled out had been modified to accommodate the seat track it was on. My new seat frame holes don't line up to these seat tracks either, I assume the seat should be mounted to some sort of seat track assembly but I can't find any pictures showing what it should look like.....Help.
On mine, which appears to be original there are not tracks. There seems to be a bracket in the the floor that bolts from the seats sit in to and you tighten it down.Anybody else able to help, I think I'm right?Mine seats are fixed and do not seem to adjust.
on my 49' the longer driver's seat is set on a track,,,
heres a pic of an extra one i have
http://i255.photobucket.com/albums/hh144/elhippie64/1-3.jpg
I just went to look at mine and the wider drivers seat is the same as pictured (makes sense for adjustment) all the others are fixed.
OLTrucks
Unregistered
OLTrucks
Unregistered
elhippie64 Looks like he has the captured image of the right ones they match all the ones I have seen for the drivers seat and as on both of my burbs. And as per the 29-57 Masterparts
