| | | Forums66 Topics128,105 Posts1,056,542 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I am rebuilding the original tie rod ends on my 57 1/2 ton. The ends of the tie rod housing has a large slot & pin through it. I got the pins out and got one side off by using a thick chisel & vice grips & un-threaded the slotted end. I can't get the other end off. I twisted my chisel like a corkscrew. Is there a special tool for doing this, or do I need to buy a huge flat screwdriver & turn it with a pipe wrench?  1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | This is the tool you need. Mac, Matco, and S&K also have them. Craftmat has them listed in the catalog and online, but they don't necessarily carry them in the stores. They don't in the one here, anyway. The tool truck or if your local parts store carries S$K might be the best bet.
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Thanks guys. I will try the home made tool first. If that doesn't work I will have to break down & buy one. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
