1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56471 02/13/2006 10:55 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | I´m looking for a PCV valve for my 261. Searcht the usual vendors up and down but no luck. :confused:
Any ideas?
Thanks, Frank | | |
#56472 02/13/2006 12:47 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Here is the website of a friend of mine that details how to install one, and gives the information on the pcv valve he installed. http://www.speedprint.com/Deves50/pcvinstall.php | | |
#56473 02/13/2006 12:58 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | that´s a great site, thanx a bunch.
Are all the valves the same or do they have different specs for different engines and vacuum?
If possible I want a a valve with a metal housing because I don`t want anything modern plastic at my engine. Any vendors?
Frank | | |
#56474 02/14/2006 3:42 PM | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Another option is to leave the road draft tube in place thus retaining the correct look. Drill the appropriate sized hole in the middle of the flat spot as the tube leaves the motor. Add valve. Plug up bottom of tube. Run rubber hose to intake.  | | |
#56475 02/15/2006 12:28 AM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Yet another option if you wanted to keep the draft tube is to use a short length of neoprene hose ( fuel grade ) which slips over the draft tube. Its held in place with a couple of hose clamps. In the bottom end of the hoze I fitted a brass plug that I had drilled to fit a rubber grommet. The pcv valve fits snugly into the grommet and a hose goes from this to the inlet manifold. The advantage is that it only takes a couple of minutes to take off , if you ever needed to. I'm working on a filter at the moment to reduce the amount of gunk going into the intake.
The idea came from Yachtcare who used to post on the board a while back.
Cheers
Bob | | |
#56476 02/17/2006 4:14 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | a valve is going to use intake vacum so use a valve from a small engine putting it in the road draft tube is a good idea as if you just stick it in the vc it could suck oil it needs to be removed from the chance of sucking oil also if will have tobe large enough to handle the crankcase preasure...doc | | |
#56477 02/17/2006 4:17 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | a valve is going to use intake vacum so use a valve from a small engine putting it in the road draft tube is a good idea as if you just stick it in the vc it could suck oil it needs to be removed from the chance of sucking oil also if will have tobe large enough to handle the crankcase preasure...doc | | |
#56478 02/17/2006 5:20 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Hey guys educate me a little here what are the advantages of running a PCV on a 235 other than the possible oil drip form the draft tube? Thanks George | | |
#56479 02/17/2006 6:58 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Doc, almost all factory PCV systems (including the ones used on late 30s-late 50s GMCs) used a valve cover fitting. If you're that worried about it, a small baffle can be welded to the inside of the valve cover under the hole. | | |
#56480 02/17/2006 10:13 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | that is what I was trying to get at just don,t stick in the vc without some mods to not suck oil..doc | | |
#56481 02/18/2006 6:28 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | gmcpanel, is it possible that my 53 1/2 ton gmc 228cu is a factory setup as it has an elbow in the VC with a rubber hose to a pcv and then to a connection in the intake manifold? (there's no mod to keep it from sucking oil. it does suck some, using the road draft tube as the inlet for the air flow but it doesn't seem to matter to the engine. i think it like burning a bit of oil. tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#56482 02/18/2006 6:59 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Old_blue, check out the GMC forums. I think the factory PCV systems eliminated the road draft tube (my dad's '51 350 has the setup), but I'm not 100% sure. | | |
#56483 02/18/2006 10:42 AM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | George,
Apart from reducing the oil drip, a PCV is much better for the environment. All those vented gases are being reburnt. Should also help oil leaks from the engine. You may also get slightly better fuel consumption. The engine seems to run a wee bit quieter and smoother idle. Definitely worth doing.
Cheers
Bob | | |
#56484 02/20/2006 2:10 AM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | i once used a cap with pvc valve from some old dodge or plymoth. the cap thing fit over the draft tube ( turned up and cut to length ) on 54 pontiac 8. ran better with less oil loss.
"It ain't a truck if you can't hose out the cab."
