4 members (Steelonsteel, bajabob, Hotrod Lincoln, 1 invisible), 172 guests, and 3 robots.
Topics128,261
Posts1,058,327
Members48,485
I am rebuilding the original tie rod ends on my 57 1/2 ton. The ends of the tie rod housing has a large slot & pin through it. I got the pins out and got one side off by using a thick chisel & vice grips & un-threaded the slotted end. I can't get the other end off. I twisted my chisel like a corkscrew.
Is there a special tool for doing this, or do I need to buy a huge flat screwdriver & turn it with a pipe wrench? headscratch
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
This is the tool you need. Mac, Matco, and S&K also have them. Craftmat has them listed in the catalog and online, but they don't necessarily carry them in the stores. They don't in the one here, anyway. The tool truck or if your local parts store carries S$K might be the best bet.
Bill Burmeister
Or if You can not find one You can make Your own.
http://s559.photobucket.com/albums/ss39/sparky52/tool/
it is easy and cheap
Have fun , Pete
Thanks guys. I will try the home made tool first. If that doesn't work I will have to break down & buy one.
