| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 19 New Guy | | New Guy Joined: Nov 2007 Posts: 19 | I bought a 66 c-60 that belonged to a fire sept. and so far my top speed in 4th gear is approx. 55 mph. Anybody know how fast I will top out at when towing 11000 LBS with a 327 block?
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I think I'd be worried about how well I could be stopping once I got 11K going 55 mph. | | | | | Joined: Nov 2007 Posts: 19 New Guy | | New Guy Joined: Nov 2007 Posts: 19 | I think I'd be worried about how well I could be stopping once I got 11K going 55 mph. Hmmm. The brakes respond very well and are in fact very sensitive. The springs and axles are rated for 23000 lb payload. Weren't these trucks rated to tow at least 11000 lbs? Why the concern about braking other than the obvious? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You've clearly never found yourself unable to stop a towed load before. If the truck is rated 23,000 you are probably fine stopping it from any speed the stock motor will achive. But I say that assuming your brakes are in tip top shape.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | There's a bit of differecne between the traction and braking ability when you have 11,000 lbs over the axle, and when it is pushing you down a hill. Those big buggers had more baking capacity on the rear end than the front & without a load over the axle you're more likely to lock them up with a heavy towed load.
Besides all that, isn't there a requirement for brakes on larger trailers in NY? I know there is here. With proper trailer brakes it's less of an issue. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | This is a quick guide to state trailer brake requirements. http://www.rockettrailers.com/TrailerBrakeLaws.htm Also, you need to check the tag in the door. If the Gross Combination weight is 26,001 or more, it is considered a commercial vehicle and is subject to USDOT regulations. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think the NY CDL weight limit may be something less than 26,000 lb, check into it if it bothers you. | | | | | Joined: Jul 2008 Posts: 86 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 86 | In West Virginia it's truck GVWR greater than 26,000 OR trailer greater than 10,000 OR combined GVWR over 26,000. Since the truck is 23,000, any trailer greater than 3,000 would put you into CDL here. I'll have to get a CDL if I ever decide to tow a trailer greater than 3,000 with my GMC 4000, GVWR 23,000. | | | | | Joined: Jul 2008 Posts: 86 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 86 | Correction. In rereading the CDL manual for WV, it appears that if the trailer is less than 10,000, a CDL isn't required unless the truck itself is greater than 26,000. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Federal law is 26001 or greater gross combined weight of the truck and trailer. States can make laws more stringent than that, but they cannot make them more lenient. If you gross over 26001, you fall under federal motor carrier laws. About the only exception for farm commodities in certain states, but you must be careful how your state interprets the law. | | | | | Joined: Nov 2007 Posts: 19 New Guy | | New Guy Joined: Nov 2007 Posts: 19 | There's a bit of differecne between the traction and braking ability when you have 11,000 lbs over the axle, and when it is pushing you down a hill. Those big buggers had more baking capacity on the rear end than the front & without a load over the axle you're more likely to lock them up with a heavy towed load.
Besides all that, isn't there a requirement for brakes on larger trailers in NY? I know there is here. With proper trailer brakes it's less of an issue. Thanks, excellent logic. I have a brake controller in my F-150. Anybody know what's involved to wire it in my 66 C-60? Can it be done inexpensively? Any reading I can do to do it myself? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't have a big trailer but the modern brake controllers don't have any interaction electrically with the tow vehicle other than providing a power source. | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Unless you are planning to haul commercially, you don't need the CDL. A non-commercial Class A or even a B (like the farmers, RV and firetruck drivers are supposed to have) will do and you don't have the added hoops to jump through. My understanding, anyway.
Adding an electronic brake controller to your Big Bolt is pretty simple -- I put one on my '65 Firetruck. Just follow the directions that come with the unit. If you need a source, check the links page for trailers. I got mine (plus a nice integrated pigtail) from lowcosttrailersupplies.
r, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Federal motor carrier laws were written to exempt farmers and rv's. If a person is hauling something that he just purchased or is transporting something to where it will be sold, he is classified as a private carrier, but is still regulated by Federal motor carrier safety regulations. If you stay close to home and know the local troopers, you will probably never be bothered. However, if you are involved in an accident, it becomes a serious. I have operated trucks for over 45 years both as a private carrier and as a motor carrier. I have seen people unknowingly get into some pretty ugly situations. "Commerce" is interpreted pretty broadly, and it is difficult to convince a court that you were transporting something merely to take it for a joy ride. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | Is there a govenor on the carb. None of these trucks were built for speed but rather towing a load at a safe speed | | |
