4 members (Hotrod Lincoln, artinva, Bill Hanlon, Opelika Tom), 67 guests, and 2 robots.
Topics128,078
Posts1,055,935
Members48,430
#561647 08/03/2009 1:27 PM
I know this topic has been discussed but I wanted clarification. I have an aftermarket lighter installed. There is the clip directly on the back for the hot wire. There also seems to be another place on the side for a ground wire. In the accessories manual it shows a wire for the light but no ground. Do I need a ground wire or is the connection to the dash enough. Also, where does the hot wire run to? Fuse block or ignition>
Thanks again,
Brian M
What year truck? 55-59?
Here is a photo of a unit with no light but it has a tab. I'd say that tab is for grounding (but the unit could also ground through the socket to the dash).
I have used a similar unit on a 6v and 12v 1954 truck and did not connect a ground wire to the tab. One of my units had the bulb fitting and lead.
Thanks for your reply. Sorry, my trucks a 59. Thats the same lighter I have and it has that tab. I had heard you don't need to ground.
Where did you run the power to? The fuse block or the ignition switch?
Thanks again
the ground doesn't need to be used on a metal dash - the hot wire should be fused, either at the fuse block [if you have an original there's a position for it] or with an inline fuse
Before 1954, the lighter was not fused and the lead wire was attached to the tail-lamp lead on the light switch (which I think had an overloads cut-out).
In 1954, the lighter was attached to the battery lead on the ignition switch. The installation diagram does not show a fuse - I put an in-line fuse in mine (as Bill suggests, above).
Thats what Ill do. Thanks for help.
Brian M
