| | | Forums66 Topics128,139 Posts1,056,455 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 13 New Guy | | New Guy Joined: Feb 2008 Posts: 13 | Dose any one know the correct way to hook up a 2 speed wiper motor to a switch.Also I need a good wiper switch to use.I,m not using the factory washer motor.So I,m not sure what terminal is for high and low.Plaese help.Con tact Bruno at [email protected] Thanks.
| | | | | Joined: Mar 2000 Posts: 1,181 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,181 | You can buy an entire wiring manual for your truck from our sponsor, American Classic, for $7.50. here | | | | | Joined: Feb 2008 Posts: 13 New Guy | | New Guy Joined: Feb 2008 Posts: 13 | Yes I have that book,But it dose not explan witch terminal is what.But thank you for your help. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Wiper motors are not the easiest to hook up, since there is a set of internal contacts that shut off the motor when the wipers are down. You don't have the factory wiper motor so you may just have to put it on the bench with power and play with it. That may be the only way you will find it's off position so you can correctly mount it. The factory wiper switch grounds the wiper motor, that way it has power till it reaches the off position internally. I'd try and find a switch for what ever wiper motor you do have. There have been posts on the factory setup you might try a search to find them, and see if they help. Good luck.
LG
I don't own a vehicle that isn't old enough to drink. | | |
