..when i swap the axles and replace the leaf springs i would like to add 2-3 inches of lift to the truck.
Have your new springs made with the desired lift. I've used
Earon Detroit Spring with great results and service, they made custom springs for my 52 1 ton.
Also consider the effect of swapping a 2wd front axle for a 4wd axle if that's what you're doing? That swap will gain you 4-6" with the original springs. Measure the spring pads up to wheel centerline on the old axle and add that to the radius of the new axle tube plus the thickness of the spring perch to calculate the lift of just an axle swap, assuming spring over axle.
If you use longer spring shackles you should definitely check and correct the pinion angles. You should check and correct if needed no matter what when swapping axles.
Try this Tech Tip:
http://www.stovebolt.com/techtips/driveline/setup/index.htmlGrigg
