| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55884 02/01/2006 1:35 AM | Joined: Oct 2005 Posts: 41 New Guy | | New Guy Joined: Oct 2005 Posts: 41 | Need suggestions for good source of information before starting rebuild of 56 235 truck motor. I don't have an OEM service manual for a 56, does the manual have adequate instruction, specs and illistations or is there a better resource?
You never have enough, til you have too many!
#55885 02/01/2006 2:25 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there may be other info sources [like aftermarket manuals], but the shop manual is pretty complete, and is worth having for all the other info too
Bill | | |
#55886 02/01/2006 2:41 AM | Joined: Oct 2005 Posts: 41 New Guy | | New Guy Joined: Oct 2005 Posts: 41 | I'm building a 56 motor for my 46 truck, the 46 manual I have is not great for this type of work. I'm hoping the newer manuals were more informative. Thanks for the reply
#55887 02/01/2006 5:25 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Cheesehead - I've got a 57 motor in my 46 and you will need both manuals. Lots of good info in them. The 56 manual should have everything you need. You might also try to get an older Chilton or Motors manual that will cover that year. You can never have too much information. Good luck George | | |
