2 members (TooMany2count, Otto Skorzeny), 47 guests, and 2 robots.
Topics128,049
Posts1,055,676
#558537 07/24/2009 9:37 PM
I was wondering what the consenus is on paint to be used on running boards.
A regular paint job would scratch very easily.
I suppose a step attached would work,but is a little unattractive.
just-a-hacker
'49 3100 before '99
Ex Hall Monitor
Ex Hall Monitor
I've seen them painted with the do-it-yourself bed liner stuff.
Tiny #558752 07/25/2009 11:40 AM
3M and SEM have an aerosol clear (it comes in colors too) called chip guard in varying degrees of texture. It's used mostly for rocker panels, but I'm pretty sure if it'll stand up to rocks and gravel, it'll take the soles of shoes.
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
Trouble is, when your shoes are wet, its not to hard to slip off the running board.
Some texture is good.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
GM's accessory running board step plate does not stand out (it is black) and it does not show scratches and it is "slip proof".
Mine are slip proof all the way and with a lifetime warranty too. No need to grab on when stepping on the board and into the box.
http://good-times.webshots.com/photo/2326828900023244788XbHtst
You Tube
I used Eastwood's chassis paint with ceramic.
Apprentice
Apprentice
looks great
Tiny #558924 07/26/2009 2:32 AM
That's what I did.
Bill Burmeister
I'm thinking a textured powder coat
should look good and be durable
just-a-hacker
'49 3100 before '99
