| | | Forums66 Topics128,088 Posts1,056,125 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | does anyone know part numbers for a spring kit to fit the rear of a 1960 c60? i ordered a kit from a local brake supplier and they are close but i would have to heat and bend the ends for them to fit right.
thanks! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bucket, are there four springs per wheel, two different lengths? If so the Raybestos number for the springs is H605, that is enough for one wheel I think. I'll see if I can cross to Napa numbers | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bucket, Napa numbers for the springs is UP82487 $15.29 each, as I said I think that's enough for one wheel, hope that helps. | | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | | | |
