3 members (Otto Skorzeny, GMCJammer51, 1 invisible), 66 guests, and 6 robots.
Topics128,180
Posts1,057,145
Members48,463
I
I Offline
Having trouble trying to figure out what seems to be the promblem with my brakes. Put brake flluid in and pumped the brakes but nothing. Any suggestions please cry
1953 GMC 3/4-Ton
In Photobucket
In the wind, til the end
Sounds like you may have one of several problems, and perhaps a mix of them. Have you bled the system? If there's air in the system, you will have a low pedal and ineffective braking. Could also be a leak somewhere in the system, master cylinder, hose, steel line, wheel cylinders are all suspect. I would advise pulling al 4 wheels and drums to check for cylinder condition, plus check all hoses, lines, and the master cylinder as well. Check the bleeder screws to make sure they come loose easily. If not, soak them with B'Laster or Kroil, then try again. Check the condition of the shoes. Look for worn/fluid soaked linings. If worn or soaked, replacemnt will be required. Same goes for any leaking component, either replace or rebuild, dependng on condition.
If everyhting checks out, then try bleeding the system. I use the following method. 1, starting at the furthest away from the master cylinder (check the line routing, as it could be either the left or right rear, depending on line layout), with a helper to pump the pedal, loosen the bleeder, ho;d your finger over the bleeder enough to amke a loose seal. Then have the helper pump the pedal gently. Your finger will prevent air from being sucked back into the system. Maintain pumping until fluid comes out of the line, then repeat with the remaining bleeders, going to the next furthest and ending with the closest. Remember to refill the master cylinder after each wheel cylinder beedling to keep it from running dry. You may need to refill more often, especialy with the first one. After doing that, repeat the bleeding sequence, with a slight difference. Instead of holding a finger over the bleeder, keep it closed as the helper pumps the pedal. Have them pump the pedal about 5-6 times, hold pressure, then open the bleeder. Observe the stream, looking for bubbles. Repeat about 3 times, or until there is no air in the stream. Then repeat for the remaining wheel cylniders, again, refilling the master cylinder as you go. Remember to replace the cap after filling. Using this method should result in a good, solid pedal. I use this exact method in my job as an ASE Certified Brake and Alignment mechanic.
Bill Burmeister
I
I Offline
thanks for all the advice. I pulled back the black rubber boot on the wheel cylinder and notice some gunk in there. I also notice that one of the cylinders is missing a plug on one side also.Is that normal? I am thinking about replacing all the brake parts.I will be ordering from classicparts.com. The new wheel cylinders should come with those plugs, right? Thanks again
1953 GMC 3/4-Ton
In Photobucket
The missing part is actually a dust boot, not a plug. It definetly should be there. New wheel cylinders, or rebuild kit if you go that route, will have new dust boots, plus seals.
You might try checking with your local parts store, you may be suprized at what they can get, and posibly save a few $$ at the same time.
Bill Burmeister
