0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 7 New Guy | | New Guy Joined: Jul 2009 Posts: 7 | Howdy, Have a leaky master cylinder in the 51. Have the one that came out of a 50 on the shelf. I know the brakes changed from Huck to Bendix in 51. Are the master cylinders the same? If they are, thought I'd rebuild the one I already have out, then swap them out. Thanks, and have a great day. Bob | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Take a look at the NAPA web sight and look up both years and see if the masters were the same no's that will give You a good idea if the masters were the same for both years and they carry the rebuild kits also .
Pete | | | | | Joined: Jul 2009 Posts: 7 New Guy | | New Guy Joined: Jul 2009 Posts: 7 | That was a good idea. Went to the Autozone website and looked up both rebuild kits. Also showed pictures. Different part numbers, and parts were different in the pics. Oh well, just a thought. Bob | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | If i remember correct,1951 had a larger cylinder in the master cylinder.I would doubled check and make sure. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jul 2009 Posts: 7 New Guy | | New Guy Joined: Jul 2009 Posts: 7 | Yep, You are right. After checking, the 50 cylinder has a 1 inch bore, the 51 has a 1 1/8 inch bore. A guy can find out a lot if he'll just take the time to use a little common sense and look. Bob | | |
