4 members (Hanks custodian, Otto Skorzeny, Steelonsteel, 2-Ton), 103 guests, and 2 robots.
Topics128,060
Posts1,055,837
Members48,427
#557471 07/21/2009 2:30 PM
RKM
Offline
Howdy,
Have a leaky master cylinder in the 51. Have the one that came out of a 50 on the shelf. I know the brakes changed from Huck to Bendix in 51. Are the master cylinders the same? If they are, thought I'd rebuild the one I already have out, then swap them out. Thanks, and have a great day. Bob
RKM #557473 07/21/2009 2:38 PM
Take a look at the NAPA web sight and look up both years and see if the masters were the same no's that will give You a good idea if the masters were the same for both years and they carry the rebuild kits also .
Pete
RKM #557494 07/21/2009 3:45 PM
RKM
Offline
That was a good idea. Went to the Autozone website and looked up both rebuild kits. Also showed pictures. Different part numbers, and parts were different in the pics. Oh well, just a thought. Bob
RKM #557521 07/21/2009 6:18 PM
If i remember correct,1951 had a larger cylinder in the master cylinder.I would doubled check and make sure.
1951 3100 Chevrolet
RKM #557538 07/21/2009 7:28 PM
RKM
Offline
Yep,
You are right. After checking, the 50 cylinder has a 1 inch bore, the 51 has a 1 1/8 inch bore. A guy can find out a lot if he'll just take the time to use a little common sense and look. Bob
