| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 21 | I have a 235 out of my 59' and it is in half good shape. It could use to be boiled down and cleaned up, it cranked real easy when I first got it but when I took it apart some of the rings fell apart and there was a bunch of carbon and gunk on the tops of the pistons from sitting for so long. It supposedly ran when it was parked. So I guess my question is do I need a complete rebuild (new valves, hardened valve seats, bored, new bearings and rings, etc..) or can I use some of the old hardware? Also If I do a full rebuild how much does a machine shop generally charge for all the labor?
Yes this is my truck, No I wont help you move
| | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | IMO, if you have apart you should do a full rebuild, especially if some of it is starting to fall apart/all gunked up. It'd really suck to do half of it just to have something that you didn't replace fail 3000 miles down the road. If you're doing just a stock rebuild it shouldn't be too awful. It's near impossible to say it's going to cost exactly $xxx because things come up and prices of parts change. My guess is to have the engine completely rebuilt with all new parts and reassembled would be about $2000. Mine was over $4000, but we did lots of non-stock "improvements." Hope that helps
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Jul 2009 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 21 |
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The carbon and gunk didn't get there from sitting.
The best way to determine whether it needs a valve job is to do a compression check before you tear it down. Too late for that in your case. Since you have it torn down and you broke rings, it needs a rebuild. The rings were probably broken because of a ring ridge in the cylinders.
A machine shop needs to tell you if the ridges can be cleaned up or if you need a re-bore.
So you need a rebuild on the entire engine, block and head. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'm with cletis on this. when I had mine done, it ran me about $500. That included boiling the block and bellhousing, boring the block, new rod bushings, core plugs, all oil passages cleaned out, planed head, new valves w/installation, polishing the crank, and resurfacing the flywheel. I think I have arond another $800 or so in parts, some from Patricks (cam, intake, exhaust, distributor), the rest came from the flaps (gaskets, rings, pistons, etc). I did the assembly myself.
Bill Burmeister | | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | I can tell you. It was $530 for the head, and $1,880 for the block. Same engine as yours - and I'm also in California (where we pay a 30% premium on everything). This was a complete stock re-build, from top to bottom (parts and labor), except I provided the labor to re-assemble the engine. It's painful when you're shelling out the clams, but it's worth it at the end. I would recommend you do the same. | | | | | Joined: Jul 2009 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 21 | Thanks for the input. Cletis, I checked the compression before I took it apart and it only had good compression on 4 cylinders the other two I could actually see the ring cracked in the cylinder just after i removed the head. I know the carbon dint get there from sitting, but the gunk had moss growing on it and there were spiders and crap in the exaust so im guessing that was from sitting haha. I will deffinatley take your advice on this one though. Thanks for all the guidance!
| | | | | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | Save your money & skip the hard seats. Doug | | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | I wanted to rebuild my 235, but machine shop ran the costs at $3500.00.
"Ya Right"
If you have the money, go for it. But there are other options! | | |
