9 members (Hotrod Lincoln, Otto Skorzeny, CuzzFuzz, Shaffer's1950, SlimSix, TrknGMC, homer52, 2 invisible), 95 guests, and 3 robots.
Topics128,139
Posts1,056,451
Members48,441
#557170 07/20/2009 4:44 PM
Fuel injection is awesome when it works as it should, but aggravating an heck when it doesn't. I'm having some issues with my TPI setup. To start off, #1 & #2 cylinders were not firing. I rented a noid light from Autozone to make sure it wasn't the harness and everything checked out but now it wont even start. I verified that the distributor is firing but is there a way to check to see if the ECM is dead? If this keeps up I may slap a carb on it and call it done!!
Robert C.
I'm a Genius in the making.
1950 3600
Test everything between the injector and fuel/signal source before you oust the component itself. to test the signal at the ECM just needs a voltmeter. look up what the signal voltage is and test at both ends of the harness. DO NOT USE A TEST LIGHT ON YOUR ECM. it can cause it to burn up because there is no regulator on a test light. if you have tested all other components and they all check out it is possible your ECM is malfunctioning.
Yes this is my truck, No I wont help you move
Robert,
The TPI is batch fire (firing left bank, then right bank...). If it is fuel related, it is most likely either harness or the injector itself (swap the injectors to determine). Spark should be easy enough to determine with a spark tester.
Did you have it running prior? They wont run with the distributor 180 out (dont ask me how I know)
Depending on the year, you should be able to plug in an OBD scanner, or simply ground out the MIL and read the codes.
