6 members (Cletus1950, Gdads51, cmayna, Jon G, JW51, 1 invisible), 108 guests, and 1 robot.
Topics128,130
Posts1,056,370
Members48,441
All, I realize that there are no aftermarket fuel tanks for the 60-61 trucks but I've moved the rear cross over back so that it has the same distance as the 64-66. Has anyone identified a donor vehicle fuel tank that supports fuel injected engines? Pump in tank configuration? that fit the area on a 64-66?
1961 Chevy C10 Stepside
On my web site
Northdm,
Check out this link https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=552344#Post55234
The tank that I used from "Tanks Inc" has provisions for the tank mounted fuel pump.
I hope this helps.
Thanks so much Hot Rod John. This looks like a great option.
On my web site
