6 members (carbking, Charles in CA, TooMany2count, 1955 1 Series, Donf, FAST55), 344 guests, and 5 robots.
Topics128,160
Posts1,057,054
Members48,463
#557136 07/20/2009 2:25 PM
RKM
Offline
Hi guys,
New here. Am enjoying reading all the good stuff. Have a question of my own. Have a 50, and a 51 5 window 1/2 ton Chev. The 50 is all in parts. The 51 is running. At some point, someone has taken out the 3 speed and put a 4 speed in it. I have the 3 speed, and all the linkage. It still has the closed drive. My question is there is a cross-member installed at the tailshaft of the 4 speed. When I was taking the 50 apart, I dont remember there being a crossmember at that location.There was no transmission or drive shaft in the truck. The one that is in the 51 does not look factory installed. I would like to put the 3 speed back in the truck. Dont know if this crossmember is supposed to be there, or if the trans. hooks to the bellhousing and straight to the torque tube with no support. Thanks for all the good info you guys put out. Bob
Bob,
Welcome to the discussion board.
There was a cross member and a transmission rear support on 1/2 ton trucks through 1953. The bell-housing and rear engine support changed in 1954, so in 1954 the cross member and a rear transmission support was only found on Hydra-Matic-equipped 1/2 ton trucks.
Tim
