| | | Forums66 Topics128,109 Posts1,056,569 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | There are 3 bumpers for each door; a flat one, and a high dome and short dome. The painters removed mine and I don't remember which goes where.Factory manual doesn't specify except by part #.
Anyone know which one goes near the top of the door and which 2 go on the body?
Thanks, Mark | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the thinnest one goes in the leading edge of the door, the fattest goes at the top of the rear door pillar, the middle sized one at the bottom .... might be switched around depending on the fit of your doors
and they're not specific to a 58 burb, they're on any model TF truck
| | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | Thanks, Bill. I appreciate the help. | | |
