7 members (TooMany2count, Wheelie, Stovebolt48, Napco Mark, baldeagle, RaNfLaS, Jeff Ogden), 72 guests, and 7 robots.
Topics128,021
Posts1,055,346
Members48,420
#55511 01/24/2006 12:33 PM
Guys, just HOW is the heat riser valve in the exhaust manifold disassembled?
Is everything simply 'pressed' in?
I have an urging need to split the exhaust manifold and that darn thing is in the way...
Please advise?
thanks
whizzerick
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
The flapper is tack welded to the shaft. Grind off the weld and the shaft slips out.
Thanks Cletis, I'm on it!
Whizzerick,
I just had this done on my 235 by Kansas Kustoms. He leaves the entire heat riser intact-you don't have to mess with it at all.
I'm with tlorber, I thought that one of the pluses with the Kansas Kustoms method was that you got to keep the heat riser.
Maybe whizzer is just going to take his apart and "rebuild" it!
Stuart
Yes I could leave it on but it would really help when cutting if it where off!
Whizzer,
HEY...quit goofing off and get back in the foundry..WE NEED NEAT STUFF...NOW! grin
Lost Wax Stu
Whizzerick,
What are you using for the front outlet pc? Did you find a donor that you can grind to mate up to the manifold or are you going to cast an outlet? Either way I'd like to know as I intend to split mine as well. Thanks.
Curt B.
You Tube
Quote
What are you using for the front outlet pc? Did you find a donor that you can grind to mate up to the manifold or are you going to cast an outlet? Either way I'd like to know as I intend to split mine as well. Thanks. [/QB]
I plan on MIG welding a length of thick-wall STEEL tubing and a fabricated flange. YES, it CAN be done!
Check out this interesting post on the HAMB:
http://www.jalopyjournal.com/forum/showthread.php?t=11972
I figure that for 185$, I can buy quite a bit of tubing, MIG wire and steel plate? It's a learning experience... wink
Thanks for the link. I'll do the same and use my $185 for an offy intake.
You Tube
Quote
I talked to a nice lady at Patrick's and she said they will have a batch of 200 FENTON intakes in about a month. Price will be 199$. Just another option to consider...
