| | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | any know the delco rem. plug # for a 1941 gmc 248 .. thanks kat
I like fixing stuff.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | originally it was a 44. 43 and 45 are the next choices. i use 43's in my 228 and 270 and the 248 before i spun a bearing. | | | | | Joined: Mar 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 23 | I'm using Champion,RJ8C, in my 1955,235 engine. I like em...it runs good.
KEEP ON TRUCKIN,MAMA... TRUCKIN TILL THE BREAK OF DAY... I SAID,KEEP ON TRUCKIN,MAMA... TRUCKIN MY BLUES AWAY...
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | AC 43 is a little cold for casual driving. It was designed for a truck that worked all the time because the 248 was only available in larger trucks. A 44 or even a 45 works a lot better for the way most classics are driven today. 44 and 45 appear on eBay all the time. These plugs were designed for GM engines and that's all I have been using in the 50 years I have been toying with GMC engines. | | |
