| | | Forums66 Topics128,162 Posts1,057,066 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | A few weeks ago I asked what this oil line was for, and I found out it was providing oil to the rockers, because the oil passage from the engine block was probably blocked. I pulled off the head and found the engine block's oil passage . It turns out that the head DOESN'T have the same oil passage . Mystery solved! Where can I find the correct head and how much should I expect to pay for it? If it's too much, I'll probably just replace the "mystery" oil line with better tubing, and replace the head when I need to rebuild the engine. Just curious, what engine/year would this head come from? Maybe from a full flow engine? I'm finding out that the previous owner did some questionable things just to get the truck back on the road. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You have the right head, there is never a matching hole in the head. The head gasket has the triangle cutout in it that allows the oil to flow from the hole to and up around the head bolt to the rockers.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | Dave, thanks. That makes perfect sense. I checked the entire vertical oil passage from the top of the head down to the horizonal oil passage and didn't find any blockages.
Any suggestions on how I should troubleshoot not getting oil to the rockers? | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Get the correct gasket, reassemble. Check for oilflow around the bolt like Pre68 said.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | One of the aftermarket tool manufacturers used to sell a tool that installed into the head after removing the center head bolt (with the engine assembled). By pouring the head bolt hole full of oil, inserting the tool, and smacking it with a big hammer, a clogged oil passage could be cleared with hydraulic pressure. The tool was just a close-fitting punch that allowed the oil to be forced backwards through the oil galleries, hopefully clearing a clog. I made my own tool, using a piece of hardwood broomstick whittled to fit. Worked like a champ!
Now that you have the head off, try squirting some carburetor cleaner down the oil passage and forcing it through with air pressure. Jerry
| | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | Hotrod, thanks for the suggestion. Here's the oil passage on the engine block, where it meets the head. Think I'm gonna first drain the oil (it's old oil anyway) and leave out the drain bolt. Then I'll fill the oil passage with carb cleaner. If there's a block, the oil passage should fill to the top and I shouldn't get anything coming out of the drain. Then I'll apply some air pressure and hopefully stuff will come out of the drain. Suggestions? | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | I seem to remember a problem with a camshaft bearing that would turn in the block and choke off that passage, but the 272/292/312 Ford V-8's also did that, so it might be my CRS kicking in!. If you choose to reinstall the external line, go with a piece of 3/16" steel brake line routed around behind the head. It looks better, and it won't starve the lower end for oil the way a larger line might. You really don't need a lot of oil flow to the head to keep the rocker arms lubed. The 216's got by with a 3/16" oil line through the block for many years. Jerry
