1 members (Guitplayer),
85
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | I was wondering if the front axle on a 1953-1959 chevrolet 3/4 ton. Will swap over onto a 1946 3/4 ton truck. Or if its possible to swap just the hubs, drums and backing plates onto the 1946 axle. The reason I want to do this swap is to get away from the original huck style brakes.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The axle from a Task Force truck is different than that under an Advance Design truck so your range is too wide for the answer to be yes.
It is lik3ly possible to swap an Advance Design axle under an Art Deco truck but I don't know how much trouble it would be.
Regarding swapping hubs and drums and backing plates, lots of people have done this on a half ton, hopefully someone will come along with a report on a 3/4...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The '53 to '55 1st series axle should bolt into your truck.
I did the bendix brake swap on my '52 3/4 ton axle. I used my original hubs. I believe the 3/4 ton axle and spindles are the same part number from '46 to '52, so you should be able to do the same thing with yours, but I would confirm the numbers with a parts manual first...I don't have mine handy right now. | | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | Can anybody give me the part numbers to the sindles, backing plates, hubs and drums for a 1953-1955 chevrolet 3/4 ton truck. And how what years these parts were used. | | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | What year model truck did you get your brake drums and backing plates off of to do the bendix brake swap? because the hubs on your and my truck have different part numbers but the drums and backing plates are the same? | | |
