0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
Finished welding the bed together for Emily. Will be painting it this week and hopefully have it permanently mounted by the end of the week.
I need a space of 1 inch to 1 1/2 inch between the frame and the bed main sills. What would be best wood to use? Pressure treated? Oak? Other?
Scott
Not pressure treated, the stuff they use now is hard on steel.
White oak that's been sealed or painted well is my choice, or some of the tropical hard woods are good for that too.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
You need something hard like oak. Pressure treated woods are soft woods. Even untreated oak will last for many years.
seeing as that you are in yellow pine country that is what I would go with. It is denser than white pine though a little more forgiving than w/oak. if your going to use oak then you may as well use a steel or aluminum block. all the newer gms use a steel shim betwee the box and frame.
if you use wood over size the hole a hair so that it allows for shrinkage and won't vind on the bolt and split
ron
