6 members (FAST55, 2-Ton, Oldcaliforniakid, Ponchogl, Hotrod Lincoln, Donf), 99 guests, and 2 robots.
Topics128,042
Posts1,055,519
Members48,424
#552162 07/03/2009 1:14 AM
Ive looked at old post but photos won't come up for me. Does anybody make patch panels for the side of the panel portion that meets the running boards? And also the piece (I'll call it the cargo corner) on the rear corners of the truck?Thanks, Brian.
Rear corners are available from Jim Carter. They are made by http://www.oldgmctrucks.com/page0215.html.
The side panel has a curvature that is supposedly matched by the outside skin of a standard 47-54 side door.
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Here's the most recent update on his info...Joe
Ray Stanley
Wheelwright Restorations
92 Pine Street
Wheelwright, MA 01904
1-413-477-6467
[email protected]
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Also here's Ray's eBay store where you might (hint hint) find what you need...Joe
Thanks A LOT!!!!! Exactly what I (and all rust belt guys) need. Thanks again, Brian
Oldog in Md.
Unregistered
Oldog in Md.
Unregistered
Briank ,
Ray is the man !
Also the door skins do not work for this repair they do not reach around the curve enough to make the weld underneath
