6 members (55shaker, Jay R, 49choptop, Lightholder's Dad, Otto Skorzeny, carbking), 113 guests, and 1 robot.
Topics128,259
Posts1,058,298
Members48,485
#551745 07/02/2009 12:25 AM
Ok, My 52 got a new gas tank recently. Before it was replaced the gauge in the dash did not work(found out why when i pulled the sending unit-In peices) While tank was out and wiring disconnected the gauge read full with the key turned on for a few days, then the gauge stayed a empty. Replaced the tank and sending unit connected the wires they way the were removed. the gauge still shows empty.
I ordered a new gauge but before i install it can anyone help with the wiring?
Jacks1952 #551754 07/02/2009 12:45 AM
you might get more bites if you put this in the electrical section but then, you might not..
this link might help.. click here
Redryder pix
My Hotrod
joker #552021 07/02/2009 6:25 PM
6v electrical system?
12V
Jacks1952 #552122 07/02/2009 11:22 PM
How many wires are to be connected at the sending unit?
Jacks1952 #552125 07/02/2009 11:37 PM
One wire from the gauge. Some people run another ground wire from a sender attachment bolt/screw to any good ground point.
That is how i have it wired and the gauge does not work correctly. New gauge and sending unit. With the sending unit removed from tank and manually operated the guage goes from the dot closest to the E (im assuming 1/4 tank) to inbetween 1/4 and 1/2 with the float at the full position.
Jacks1952 #552430 07/03/2009 11:05 PM
test it BEFORE you put the sender back in the tank
hook up the two wires [gauge & good ground] and actuate the float......... see if your gauge /sender works 1st.
BEST if put this in stovebolt electrical
Jim & Caroline
